Hi, Does anyone know or have any experience with airbag light on dashboard?
I'm currently looking into a car that seems to have this fault and is it cheap or expensive to fix and get fully repaired?
Ask yourself, if was a simple fix, why not sort it out before selling the car.
Both the above answers are spot on, it’s like adverts that say AC not working, just needs re-gassing……so why not get it done and sell the car more easily and for a bit more dosh?
Airbag could be anything from a dodgy connector under the seat (easy) to an actuator or airbag module (very expensive).
The main point is you get what you pay for. If a car is cheap then there is usually a good reason.
Walk away, as Moleman says, if it was an easy fix they would have done it.
