Hi All,
Well just another is220d issue, after replacing injectors, cleaning EGR valve etc troubleshooting a smoking issue. After replacing the 5th injector the car is no longer starting. It actually stopped starting when the old 5th injector was still in the car.
It cranks and nothing more, I may have primed the system about 3 times now and I read somewhere that you shouldn't prime the system unless you run out of fuel. There was fuel and just topped 5lt as well for good measure incase gauge is not reflecting correctly.
Could this be the cause or how can I check airlock if anyone knows.
Cheers.
