1996 LS400 Reluctant reverse gear
Howplum
Earlier this morning the gear selector refused to move all the way across the N position to select reverse gear, although turning the engine off and on again seemed to cure it. There was no problems engaging forward gears. Any ideas?
I'm hoping it was a one off, but obviously I am very wary of going anywhere that might involve reversing.
I once had an old Mini that wouldn’t engage reverse but that was easy enough to push backwards 😀
I would first lift off the wood trim and take a look for something stuck in the selector gate. It sounds more of a mechanical selector problem than a transmission fault.
Sounds like the solenoid that prevents the gear selector being moved from N to R unless the brake pedal is being pressed is sticking. Stripping down, cleaning and lubricating would probably fix it.
The gear selector is quite complex:
https://lexus.7zap.com/en/eu/lexus+ls/431220/ucf20r-aepgkw/2/3312/330285b/
press that small odd-ball oblong selector thingy just to the top of the selectors, the one that takes you out of gears etc ..  can't remember it's name ...  that might free-up summat that's " sticking "
Happened to me once, stuck in gear and wouldn't move !  and i pressed that and all's been well since .....  some years back tho'
Just a thought!
That's the shift lock override button Malc. I tried that, but it didn't seem to make any difference. Anyway, it's something else to check, which I will do in a logical manner, instead of being in a bit of a panic whilst stuck in the middle of a manoeuvre in the road!
Just as a comparison and of course a bit of useless information the LS400 with RWD has a turning circle of 10.6m, a FWD BMW Mini is 11m.
The ultimate of course is the “London Taxi” with a required maximum turning circle of 7.62m (25 feet) to ensure they can turn round at the Savoy Hotel without reversing.
  • Like 4
I've often felt this to be a huge advantage with my Lexus when comparing turning, parking. manouvering  etc with my Honda Legend which by comparison seems a trifle clumsy
  • 5 weeks later...
11 hours ago, Howplum said:
I've just returned from a two week holiday, and whilst away connected a charger to the battery. The car now is behaving itself, so perhaps the issue was battery related.
These cars do repair themselves Howard!
The solenoid is highlighted, the button is to the right and of course being Lexus there is also a shift lock solenoid computer at the rear of it.
Normally a combination of dust, crud and carpet fluff causes issues, access is tight but a paint brush and vacuum would be the starting point for a clean out after removing the wood trim. ( use a wallpaper scraper with a layer of electrical insulation tape to prise it up at the rear sides).
  • Thanks 2
