cannot adjust position. is on highest pos. stuck and no more suspension, ride is extr. hard. any help pls.
I don't know but... I would definitely search this specific RX forum for "air suspension" issues.
I'm sure another member has had similar issues?
If this issue is similar to the one on the 430 then it could be ride height sensors - Water ingress causes a short resulting in them being stuck on high and very bouncy ride - fix is usually to replace them (or remove and clean electrics)
