Get the Lexus Link app. Has find my car function
Yes if it was more reliable it would be great however I am often sitting at home and the Lexus Link app says that my NX is 40 miles away in a location that I visited 48 hours previously!
I went for this one a couple of years ago (when it was cheaper!) and there were few trackers available that didn't come without an extortionate monthly subscription: https://www.amazon.co.uk/TKSTAR-TK905-Rechargable-Positioning-Waterproof/dp/B071FQNQ1L/ref=sr_1_3?crid=17VR4RSX3RIOK&keywords=vehicle+tracker&qid=1664725393&qu=eyJxc2MiOiI0LjkwIiwicXNhIjoiNC4xNCIsInFzcCI6IjMuNTQifQ%3D%3D&sprefix=vehicle+tracker%2Caps%2C89&sr=8-3
Above still needs a SIM card of course. Being a Chinese model, it wasn't recognised as a valid tracker by one of the Insurance Companies that offered a discount for trackers. I like that it has a Battery, that lasted about 3 months a charge when it was new. Now lasts about a month. I did buy a 12V/24V adapter (about £12 IIRC), which worked very well but I'm not using that at the moment.
If I was looking now, I would certainly check out Herbie's recommendation, looks good and very reasonable.
Just got the TRACKER S5 Plus 3 Year Subscription from Lexus bolton
Looks good, nice app, finds the vehicle alright
  • 1 year later...
My RX350 came with a tracker that was a DIY fit from the previous owner so just had to create an account and pay the subsciption fee which is very reasonable in my view. Its only been a couple of months but so far so good. https://tracetrax.com/car-gps-trackers/ .
On 10/2/2022 at 3:23 PM, Herbie said:
If you want to fit your own tracker I can highly recommend the DB2 from Rewire Security:
https://www.rewiresecurity.co.uk/db2-self-install-diy-gps-tracker
Herb Was Looking At This..Seems easy To Install But Does it drain The 12v Battery..And what subscription did you take out..ie 12 24 36 Months..Thanks.. Also do you recommend any other accessories..? Thanks
It's very easy to install Ronnie, takes about 5 minutes tops.
It doesn't drain the 12V Battery and one of the sensors even shows current Battery voltage.
I initially took out the 24 month subscription but I think I'll go for 36 months next time as it means you avoid any price increases. Highly recommended my friend.
It doesn't drain the 12V battery and one of the sensors even shows current battery voltage.
Many Thanks Herb... Good advice..!!!
Herb.. Just ordered the DB2 tracker  From amazon £14.98.. Yes it was on offer and is supplied from Re-wire P+P free Contacted them directly this morning and they wanted £34.98 so saved myself 20 Quid which i can set aside to pay the Subscription...Will get it Monday... Have you by Chance installed a line fuse with the Tracker or a witch to control on/off function..And did you hide the unit in the boot or not.. Would be interested to know...Many Thanks Ron
