Hi.
Had a bit of work done on the old girl: parking sensors replaced, new water pump and cam belt, new rear shock absorbers and springs and O/S rear hub ball joint.
I also asked them sort out the fuel level sender unit as the gauge drops from 1/4 full to empty each time.
The garage said they'd got one from Lexus but it wasn't the correct one and Lexus said that's all they had.
I can find plenty on eBay but there are several different numbers.
Does anyone know if a specific part number is relevant for a '54 plate RX300, or how I can determine it?
TIA.
John
On 9/19/2022 at 10:11 AM, ColinBarber said:
Look up on toyodiy.com using your VIN.
Thanks Colin. Will do.
