I have a 2019 NX which for the past 3 months has had issues with the boot sticking at various positions which I reported on the last service but dealer could not find anything wrong. Last week it packed up altogether and after being told it is just a re programme required, I have now been informed that it requires two new strut’s. Fortunately Lexus have agreed to sort this out under warranty even though the car is just over 3 years old. However, I was told that it would have cost £1300 to replace these. Has anyone else experienced this problem because I am hoping that this is not a reoccurring problem as the parts are on a 7 weeks delivery and I am unable to use the boot during this period.
SGS ( well known and well respected )  re-gas gas struts if that's the issue
At 3 years young your car shouldn't need anything like this replacing surely :unsure:
No idea what re-programming you need unless it's summat to do with the electronics from switch to strut not reading .................  too complex for me these modern high tech cars
I think simply finding out WHY you need NEW STRUTS would be a good start ....... are the struts worn out ( surely not ! ) or is it the electronics that's awry maybe ?
Sorry  ..........  I can't offer any other thoughts here
Good luck
Not a common issue but as long as you have the car serviced at a dealership they'll continue to be covered by warranty, so stop worrying!
Good luck
These are motorised struts, not gas struts
Not heard anyone else report this problem so you were possibly just unlucky. There was a part code change for MY19, so maybe we will see a pattern of the early 2019 vehicles with this issue - time will tell. The part is specific to the NX but I imagine the main component is the same for RX and UX and I've not heard of issues there either.
Normally the fact that the part is coming from Japan would indicate this isn't a common issue otherwise spares would be held in the UK/Europe - but with current supply chain issues it is more difficult to make that assumption.
As Steve has pointed out, Lexus Relax warranty will cover these for up to 10 years provided you get your vehicle serviced by an authorised Lexus dealer.
  • Like 4
  • 1 year later...
Hi, 2018 nx tailgate makes an horrendous noise when closing. Just been for service
asked then to check it out. Told needs new struts @ £2211.40 which I think is a bit excessive.
My question is should it not be done under warranty?
if not under warranty then might be good to explore the SGS route above if that's possible .  might save you a fortune £££
  • 1 month later...
  • 6 months later...
I have a 2020 Lexus NX300h, only just out of warranty and the tailgate opens an inch at a time and beeps twice each time I press the button in car or in remote. After 5 times it automatically closes and seals. I would not expect the struts to need replacing after only 4 years and 5 months. Could they just need lubricating?
If the car has been serviced at main Lexus dealer you will automatically get another years warranty.
Although the ‘Relax’ warranty is not as comprehensive as the initial warranty, I would like to hope it would covered… worth a phone call 🤔
These electric tailgate struts have a 6-wire connector that indicates they have a stepper motor built-in. So Ballscrew or Acme thread operation and can "stop and hold" in programmed positions as commanded by the ECU. They can be damaged or lose their calibration if obstructed or forced.
There will be a procedure for resetting the calibration similar to that used for power windows. The usual suspects (amazon, eBay, Aliexpress etc) have cheap replacement options available.
https://www.ebay.com/itm/355427311700 for example.
