2008 RX400h Rear Bumper removal
I couldn't find anything through search unfortunately...
I've found water ingress at bumper level into the boot, so want to remove the bumper and see if I can fix the issue (possibly cracked seam sealer?).
I can't find any guide for removal - any help appreciated.
I can see what looks like plastic clips on the inside of the wheel liner, but they refuse to budge and I don't fancy wrecking them - any hints :)
On 9/2/2022 at 3:11 PM, Wsurfa1 said:
After 2 months without rain, of course it's now raining...hopefully my high tech interim solution of some microfibre cloths stuffed in the boot will work 🙂
I used that high tech solution for a while too.  I gave up trying to fix the leak so I came up with another long-term solution:  drilled a few small holes to let the water out.  🤣. Problem solved!
