Not sure if I'm missing a trim piece in the but in the driver's door, I can see a screw, which seems very un lexus like!
There should be a shaped piece of hard felt sitting at the bottom of the hand hold/door puller which would hide the screw head. Mine is not stuck down so it's probably gone missing with cleaning etc.
thank you John, I thought something was amiss!
Yep as said - felt pad.
They're not usually stuck down but firmly placed. They will get sucked onto a good vacuum so I reckon thats probably whats happened
thank you Tony that's really helpful
It's just a crappy bit of felt. You could probably get something very close the original for a few pennies from an arts and crafts shop. you obviously just need to cut it to the correct shape.
that's true, it disappeared after it's last visit to the Lexus dealer I bought it from so have asked them to sort it. They haven't replied yet....
  • 1 year later...
Are there front door versions of this? Are the rears the same on both sides? Missing them on mine too 😞
@CT200NIthe door feld is like 5-6 quid.
I bought this recently from Aliexpress and man, no more rattling inside the car! Especially the cup holder(s). If you got a solid cup/thermos, you'll know what I mean.
https://a.aliexpress.com/_EQaWI7H
10quid its a complete car set
Thanks! Do they come with inserts for the little door bits though? Maybe that's too niche.  I always thought the CT should have been lined with felt or rubber in the door cars tbh for a luxury car!
