Hi there,
i’ve changed my thrmostat in my is300h 2014 hybrid one, wanted to ask how to get the air out from the water system
Same method as any other "normal" car, really, but since its a hybrid, you'll have to enable Maintenance Mode so the engine will keep running.
Top up coolant, squeeze radiator hoses. If level drops, add more coolant then re-fit expansion tank cap.
Run engine with A/C off and heater set to max on low fan setting until the thermostat opens.
Leave engine idling in this state for a few minutes so the coolant can circulate the whole system, giving the radiator hoses a few squeezes (careful - they'll be hot now!) to "burp" any remaining air.
