2012 Lexus RX450H ABS Relactor ring broken
My 2012 RX450H front right abs ring is broken as shown in the picture attached. Obviously this is setting AFS, ABS, AWD,BRAKE warning lights on. I am based in Europe. I had previously got the car scan for fault code at Toyota dealership and code C0200 came up. They said its ABS sensor that need replacing and so they ordered the part but I stopped them after I took the wheels off and found the ring was broken. Called them again and they suggest replacing the right drive shaft instead, which comes with the ring on it. Its pretty expensive (over 1100 euros).
Can someone point me to where I can get suitable ring to buy? So far I have only found ring for RX400 from here; https://www.reluctorrings.com/cars/lexus
Any help will be appreciated.
