Hi GLYNNY HERE.
IF YOU NEED  A REPLACEMENT  Battery FOR YOUR LEXUS I.S. 250 2011, THIS  ONE IS A  DIRECT REPLACEMENT.
TOYOTA No. 28800-YZZZL. THIS REPLACES No.28800-YZZJC. EXACT FIT INTO BATTERY  COMPARTMENT.
HOPE THIS HELPS  SOMEONE LOOKING FOR A  REPLACEMENT  Battery. GLYNNY.
On 7/2/2022 at 7:20 PM, GLYNNY said:
Hi GLYNNY HERE.
IF YOU NEED  A REPLACEMENT  BATTERY FOR YOUR LEXUS I.S. 250 2011, THIS  ONE IS A  DIRECT REPLACEMENT.
HOPE THIS HELPS  SOMEONE LOOKING FOR A  REPLACEMENT  BATTERY. GLYNNY.
How much are they, just out of curiosity? I'm only asking as I needed a Battery a couple of years ago and I just went into Halfords and got the cheapest one rated for my car and it's been absolutely fine for less than £100.
Battery  for your  lexus.....
It cost me £111-00 from my local TOYOTA  dealer
Part no. 28800-yzzzl. Perfect fit for I.s.250 2011.  GLYNNY.
Or you could get the Bosch ( like many others on here have) for £87 Del ( at the moment on flea bay)
S4 026 Bosch Car Battery 12V 70Ah Type 068 S4026
Keep in mind that most Battery brands are simply rebranded as there are not that many manufacturers.
For example, Bosch is a rebranded Varta Battery. So you can save some money this way since any new Battery will come with a warranty and will last you at least a few years.
The most important part is to get a Battery with the amps suited for your vehicle or more. The Bosch Battery that I bought the car with died last year and I got a new one that runs without any issues. Bosch was 60 amps, new one us 75.
True that.
You could also get the Bosch S4 026 068 from Tanya Batteries at £81.47 delivered.
Choices are always out there 🙂
  • 3 months later...
Hi all.
Can anybody please advise me what is the difference between SKU:28800-YZZZR ISP2 at £84.00 pounds. and SKU: 2880-YZZZL ISP2 at £106.59 both from Lexus parts direct both for a Lexus IS 250.
Thanks.
65mike
Being L and R one will be for RHD and one for LHD.
Hi all.
Arqum I don't think it means rhd and lhd as there was also a yzzjc so I don't think this is correct.
65mike
What’s coming back when you ask them to match against your Reg as I know the is250c had a higher rated Battery for the roof. I gave up on the Lexus batteries as I had two go bad in less than 6 months. Got a Bosch instead from Tanya and going strong after 3 years…
Hi all.
I decided after much browsing around that I would stick with the Toyota Battery as it had given 7 years service.
It was as GLYNNY said a YZZZL Battery I got to replace my YZZJC which had given good service.
I phoned my local Lexus dealer and he wanted £127.54 and I said does this include fitting his reply was no that would be £60.00 approx I nearly hit the floor.:angry:
It took me 15 minutes and no grazed knuckles to do the job and I paid from Lexuspartsdirect £106.59 including vat delivery was £5.99 DHL.:smile:
All done now no wonder dealers get little work at prices like that a nominal fee off £15.00 pounds would have been ok but £60.00 is taking it in my book.
65mike.
YUASA isn't rebranded twaddle. Propee Jaoanese manufacturing and some report it as being one of the best car Battery brands on planet earth. I ran mine well beyond 5 years across 2 or 3 different Subaru 6 cylinders and it was amazing.
That's all I ever buy now...
I have got a Yuasa in my IS250, it was a replacement for the original Panasonic and also have the same brand in 2 other cars.
Thankfully my 21 yr old LS430 also came with a YUASA. So hopefully I can be battery-worry free for at least a few years 😊
A little bit of subjective info here also https://www.honestjohn.co.uk/forum/post/index.htm?t=97640
The Halfords 5 year warranty also worked well for me as one of mine developed a fault at year three. So they replaced it without much fuss...
