Where is the best place (supplier) to get a replacement key from ? I have 2 for my '98 and they both have broken where the blade attaches to the plastic fob containing the 3 buttons.......
Peter
(York, North Yorkshire)
I have used eBay in the past without any problems
Make sure you buy the correct length key blade
Also ensure a locksmith is willing to cut a blade supplied by you - some do not allow this for fear of damaging their machines
hope this helps
IThe “best” would be from Lexus but at a price.
There are the usual suspects on eBay with Chinese copies which may last a few years.
Also consider a local locksmith who will either have the key in stock or order one for you, they would cut the key ( if allowed) and transplant the electronics.
Also found this company who offer a key cut with picture or code.
https://www.keymoon.uk/lexus-ls400-three-button-remote-key-case-toy48.html
Hang on…if the metal blade is intact you can buy the plastic housing and fit the existing metal blade can’t you?
I have found Timpsons do a fair job.
BUT make sure you goto a Timpsons at  Supermarket, they tend t o have their cutters newer meaning the key will fit (I got this from a mate who used to work at Timpsons -as wel las the chap running the Timpsons in Stroud.
Been using my replacement keys now for 5 years, no problem.
