So I've got the new TPMS seated - how do I actually program the TPMS to read with the system?
The local mechanic has no clue
Thanks in advance!
Thanks in advance!
You need Lexus or tech stream software
also needs to be genuine part
I’ve got issues at the moment
For reset there should be button under the dash, but what you mean is not "reset", but what is needed for new sensor to be "programmed". And John already explained what is needed for that.
