Audio Swap
Graeme1966
Is the Lexus Is220d Sat Nav- Stereo Media Player a straight swap out for standard unit or does it require extra wiring harness? I would like to know before I attempt to remove stock unit please.
lexus_is250_headset_headunit_dvd_player_radio_1576134184_b213b236_progressive.thumb.jpg.5a6e62ed38ef784b5a261fa72aa5b257.jpgs-l1600.thumb.jpg.4d96faa709207a4f12f9b1d4414b91e4.jpg
Hi Graeme. I don't think it's a straight swap. Since you have the none nav system then if you want to upgrade then there are a number of android units available for your car. The Teyes CC3 is probably the best. However look on here as someone has installed the full screen chinese type headunit. Look on YouTube on how to install an android headunit. With an android unit you can add a reverse camera.
