On 6/13/2022 at 7:26 AM, steve2006 said:
Amayama don’t supply these to the UK for some reason.
LPD price below.
Thanks I did end up buying here - fitting it today and will report in a week or two
Hi all
Hopefully a tip for others who will have this problem
The online place (Fish brothers) ship the TPMS without a metal sleeve (this sleeve sits between your alloy rim and the sensor itself). My sleeve was corroded and cracked and the local mechanic had to make a plan
Can anybody source a part number for this sleeve?  Much appreciated!
Inserting generic pics - 1st one has a sleeve and the 2nd doesnt
Amazon.com: BOXI Qty(1) Tire Pressure Sensor TPMS 315MHz for 14-17 Jaguar  F-Type/Jaguar XJR, 10-17 Jaguar XJ, 11-16 Land Rov-er LR4, 10-16 Range  Rov-er, 10-14 Range Rov-er Sport, 12-16 Range Rov-er BH521A159CA :     614didlybmL._SL1001_.jpg
Surprised that's not included are you sure it's just not missing?
If that's the part that's failed then you would not need a new sensor just a replacement body?
I have had exactly the same issue on a non Lexus vehicle, as far as I can see the repair kits are generic to most vehicles, after all a tyre valve is not manufacturer specific, but this looks like the part you need.
https://www.amazon.co.uk/Pressure-Sensor-Valve-Repair-Chevrolet/dp/B07FM98Q6J/ref=sr_1_4?keywords=tpms+repair+kit&qid=1655371143&sr=8-4
Lexuspartsdirect do TPMS refurb kits which include seals and sleeve and are about £8 each if memory serves me correctly.
