I'm very very out of my depth here but can anyone confirm if the 4GR and 2GR have the same camshafts?
I've seen 2GR cams being sold with a slight change in timing but i've never seen a 4GR camshaft besides factory fitted. Is there any difference? Would they plug/play minus mapping issues etc..?
Ideally i'd like to increase power low to mid RPM even if i sacrifice top end power and with the VVT system installed i'm unsure if i could advance the cams if at all.
They are different. Probably just lobe profile but without a remap of engine and VVTi it isn't going to run correctly.
