After disconnecting the Battery the windows do not work other than the drivers side. Have tried the usual procedure but nothing. Guess it could be fuse but which one as not clearly marked or and extra inline fuse maybe.
Any ideas welcome
23 minutes ago, TR7 said:
the windows do not work other than the drivers side [...] Guess it could be fuse
I don't think the electrical supply is divided into left windows and right windows so if the driver's side works then I don't think it can be the fuse. Do you mean that both front and back windows work on driver's side, or literally just the driver's window?
There's an isolator switch on the driver's door master controls - have you turned that off by mistake?
Go to each window in turn and use its own controls to completely lower and hold for a couple of seconds, then completely close and again hold for a couple of seconds.
