On 6/14/2022 at 12:11 AM, John smythe said:
Lexutor - may I ask how much a new tank costs please. I’ve got an is220d and it’s leaking on the weld between the two halves of the tank [rust] . Apparently it’s a regular thing . One of the main reasons tanks fail is people use injector cleaner which destroys the tanks liner. One mechanic stated jb weld putty is a brilliant solution for leaky tanks if done correctly.
With your car did they only suggest replacing the heat shield and new tank? Kind Regards John
Sorry for the very, very later reply. I'm only now coming across your reply. I didn't see a warning I had a reply here.
Yes, they only replaced the tank and heatshield. It was a while ago, but if I remember correctly, the tank was about 800-900 and heatshield 400. That's in Euros.
