What is this noise from the dash? (sound clip posted)
NOTE: I recommend using head phones and turn up the volume when playing the clip
2007 Lexus IS 250
From the passenger side or middle dash area (definitely not driver side) I hear this noise as if a tiny metal ball would be loose and moving to the vibration, see the clip posted below.
It only happens while driving and not during stand-still, the noise gets bigger if the road is not as smooth
This noise only started in recent weeks as the weather got warmer. I definitely did not hear this sound during the winter when it was cold.https://youtu.be/fUUkVpV-lIU
It just sounds like a plastic rattle from somewhere. Rattles and creeks can be "seasonal" as materials expand and contract with temperature changes. Have you tried asking a passenger to press various parts of the dash as you drive to see if you can locate it?
Wedge a small piece of rubber or some other flexible material between the top of the dashboard and the centre point of the windscreen and see if this helps.
There is a known issue with some of the dashboard fixings.
