I have 09 Lexus is220d. The windows switch don't on drivers side for rear or the passenger side. I can operate passenger on drivers. But the actual switch on passenger don't work or rears ? Any ideas please is it the whole drivers side window buttons or something else ?
Thankyou Luke
Thankyou Luke
I think you need to go round to each door and use the individual switches to take the window(s) all the way down and hold for a few seconds, then all the way up and hold for a few seconds. If I'm right, you'll then be able to control them all from the drivers door.
EDIT - just re-read your post and it may be the 'Master' switch on the drivers door that's been pressed by accident?
Thankyou for reply. No I am not able to operate rear windows from drivers side either. Passenger side don't work either only from drivers side so bit of a odd one
