Hi All,
Just to let people know that the first edition of the 2022 maps seem to be available on Lexus Tech for MM17 and MM19 systems.
After a couple of years of minor delays in map releases due to the Pandemic, we seem to be back on a 6 month release cycle.
You can either do an over the air update of one or a small number of map regions e.g. UK only (not recommended as it breaks speed camera notifications) or copy the files onto a memory stick and update the entire map database (which takes about 70mims when you plug the stick into the car).
I haven't updated myself yet (only just seen the update go live) but will try tomorrow and report back.
Have a good Easter.
Paul
Just to say i loaded the maps onto my RX today and they worked fine. The whole process took the usual 70mins from start to finish.
Paul
