7 minutes ago, mark oconnor said:
can anyone recommend a battery for my rx300 reg2003 and can i fit myself
Yuasa are a well respected brand and yes, it's a very easy DIY job.
I'm not sure what model number you'll need but just look on the old Battery for that info.
Do you mean the remote or the large one in the engine bay?
I fitted the one for my remote myself, the other; a garage supplied and fitted a Yuasa.
Thanks pcm👍
I'm not sure what model number you'll need but just look on the old battery for that info.
Once again thanks Herbie👍
It's best practice to disconnect the negative first and reconnect last. That way if your spanner accidently touches the bodywork whilst working on the +ve you won't get a short. You may also find some things need resetting eg clock, radio settings etc depending on the vehicle.
If you want to fit it yourself then this is a good place to get one, just put your reg in and it will give you all the options, next day delivery as well...
https://www.tayna.co.uk/
