Hi guys…
On opening the R/O door on the ct200h there a small vent / grill panel I was told it’s a fan to cool down the battery…
Never knew it was there does that need cleaning & if so any videos??
Also how often should the transmission oil be changed??
Thank you đź‘Ť
The vent is there but the filter is missing on my 2014. The filter is the one that needs to be cleaned on a yearly basis.
Also the fan inside the vent, down at the Battery could use a cleaning once 5 years.
AMD (Toyota Care Nut on Youtube) recommends 6y/60k miles trans oil change with dealer oil. AMD is a toyota master tehnician for 10+ years.
Edit: this is the filter
billede.thumb.png.026e970e47cecce28b318f2383c380ec.png  billede.thumb.png.982cf4b99d8036e1a604927f46eae662.png
This filter, right side of rear seat is the one that Lexus does not clean when the car is serviced. We clean it every 4 - 6 months.
It is easy and a 10 minutes job.
Does the plastic cover just pop off?
Ă—
