I am using straight carnuba wax per the instructions.
Is it safe to first use a clay bar?
After waxing has anyone used a Mirror Glaze (IE...Final Inspection 34) followed by a sealant (IE..Sio2)
I know these products can be used on the carbon top, what about the paint, was it safe to use?
Its paint.
You can use any product that you would normally apply to any car paint including clay bar. If you're using a clay bar you need to machine polish afterwards as you'll introduce swirls to the paint by doing so
No point using a glaze underneath a sealant as the sealant wont be able to bond.
Better off polishing and putting a lite ceramic/graphene product on i.e. gyeon can coat, Siramik Lustrous Plus
