Yes, it does have a constant beep whenever the engine is off, the lights are on and you open the door. Perhaps it's a fuse or something?
I don't know if it's linked to the sunroof beeper? If my sunroof is open when I switch off the car, then it makes a series of beeps. Perhaps you can see whether that works too. If it doesn't, it may be the actual beeper unit rather than the door switches.
