Opinion on battery health - GS450h on Autotrader
I'm looking at a 2012 GS450h on Autotrader. The car seems to be good (I haven't actually seen it) but there is something potentially worrying from the pictures - the hybrid Battery seem to be very close to minimum. This is possibly caused by the car sitting unused for a while (the car has done only 300ish mile since November). From what I've researched until now the normal range of the Battery charge is somewhere between 2-8 bars.
So the question is: Is this an issue? I know it's impossible to say 100% without testing the Battery but getting an opinion is a good start.
This is the ad: https://www.autotrader.co.uk/car-details/202112060279397?sort=relevance&onesearchad=New&onesearchad=Nearly New&onesearchad=Used&make=Lexus&advertising-location=at_cars&radius=1500&postcode=ls134sf&year-from=2012&model=GS 450h&include-delivery-option=on&page=2&percentVehiclePriceDeposit=true
Shouldn't be a problem, except the traction Battery may need dealer intervention to recharge to a serviceable level. Whether the selling dealer can do this one would need to enquire.
Personally I would request the car go for a hybrid health check before purchase.
This will be my main requirement if I decide to buy it.
The Battery gauge on that screen isn't a true reading of the state of charge of the actual Battery.
We, as the end users/drivers only get to access 60% of the Battery capacity so, in overly simplistic terms, think of it as having another 20% below the bottom and another 20% above the top. The screen is only illustrating what's left of 'our' capacity.
Given that, I don't think there will be a problem in getting the car started but, as Peter said above, there is a possibility that a dealer may have to be called to get it started, albeit a small possibility.
Hello Boris,
This Battery bar looks to be taken when car is not fully powered on - I have same if I clean interior and only have radio on without ignition 🙂 As soon as you press brake pedal and start button the Battery bar will show reading 🙂
It is also right that for the most of the time you will have 6/8 bars and on 2 car will turn off engine charging if it won't chare by other means like going downhill, coasting.
  • 1 month later...
There are 2 main things to consider (as well as loads of other things like its driving history, how it was mainly driven, how often, maintenance, temperatures etc etc of course).
1/ is capacity which cannot be known for sure without full testing with the Battery removed from the car, the other is cycle life which if i am looking at the correct ad, we can only estimate with a car that has covered 160,000miles the Battery modules may now be approaching the end of their natural cycle life.
I get asked about this a lot & there is no quick or simple answer or reliable user test. If buying from a dealer i would suggest asking for a weeks test drive & I can help advise you with your experience, if they wont agree - walk away.
It's probably worth me updating the thread... I actually bought the car (almost 2 months ago) and it is perfectly fine. As Kijan suggested, the picture was taken while the car was not in "Ready". It has passed it's Battery health check since I bought it so I'll have a peace of mind for another year.
Hi Boris, I'm pleased to hear you are happy with your GS, I loved mine! - bear in mind though that a "Health Check" is purely a snapshot of the batteries' state of health at that particular moment in time it is not any form of reliable indicator of its health 1 minute or 1 year 2,3, or 4 etc years later.
