Hi, is there a tutorial how to get a 10,000 track USB drive to play on a Mark Levinson stereo ?
The source is Itunes - I move it to the USB drive using iMusic.
The USB drive is 128GB formatted to FAT32.
It looks like it only sees 500 tracks, and no artwork
Many thanks
  • 5 months later...
Many thanks
Try downloading the tracks you want on Spotify. It's got the most popular hits.
Many thanks   https://ktub.org/
You can also try listening to music on apple Music. This is also a popular platform.
Many thanks
Artwork needs to be embedded at 500x500 pixels maximum to work reliably.
If you are only seeing around 500 tracks, this suggests that you may be going over the maximum number of files per directory?  Do you just have the files split in two directories?
This table may be of use.  Looks like you cannot have 10k tracks.... the maximum is 9999!  (As a point of reference, I have around 8k files and the system works fine.... apart from broken voice commands).
