Hello,
Thanks for allowing me to join this forum.
I've been asked to sell my father-in-law's IS250.  He had a stroke a while ago and can no longer drive.
I'm not particularly familiar with Lexus cars and was after a bit of help with being able to identify the trim level and colour.  The colour is best described as a pale met green/ blue (Breakwater Blue??).  Do the IS250's have a trim level denomination?
Thanks in advance for any pointers.
Richard
Welcome Richard, sorry you are joining in sad circumstances. Do you have access to the V5 document, that should state the trim level.
If you look at the VIN (on passenger side inside the door) you will find the colour code (3 characters highlighted below (bottom left))
It is probably 8R6, which is called Brechin Slate in the UK (Breakwater blue is an American name for the same colour code).
Great, many thanks.
The V5 notes that it is a SE model (I've no idea whether that is good or poverty spec) and that the colour code is as you suggest.
Thanks for your help.
It's having a scuff on the bumper repaired on Monday and then I'll post some pictures to see if there is any interest here (assuming that's ok).
Thanks again
Richard
SE is the middle spec, and well equipped. Sat Nav is an option, so if it has that make a point of mentioning it.
You can post an advert, but please do so in the For sale forum and follow the template outlined in the rules posting within the forum.
https://www.lexusownersclub.co.uk/forum/forum/116-lexus-cars-for-sale/
