Let's add here info not easily available to us (unless you really dig deep into the manual).
Tips, tricks, staff hidden in the menu, interesting info, anything that would intrigue us to run 😄 to the car.
Today I have enabled the opening/closing of the windows using the remote. A generic obd2(£4 ebay) and carista app are needed.  "Full version" 😇 of the app is available online.
Can be done at the dealer, probably for free, but requires booking, travel, waiting, etc.
Things I've used: Android phone, apk and Bluetooth obd2
So if you already have a Bluetooth obd2 it is going to be free.
If anyone needs more guidance please let me know.
How annoying is when the tyre pressure warming is displayed. Premium, luxury car at a "respectable " price is not telling you which  tyre is loosing pressure. Not sure what exactly was the philosophy behind this decision.
Using the same app carista you can see the pressure info for each tyre.
Available under the coding menu.
I'm not advertising for the apk, is the only solution I have found. Maybe someone can share an easier way.
Another easy and fast way to set a destination point in the sat nav is by using Lexus link apk/app.
You need to connect with the car by creating a mobile hot spot using your phone.
Setting up the app is easy.
Tested using android phone and Nx300h 2015.
Source- lexus.com:
Closing the power hatch is a longish 8 seconds and you cannot lock the car until it's closed. You cannot force it closed manually, unless you disable the power feature in the multi-information display.
To disable the hatch:
Lexus NX 1st gen  personalised setting:
Dings & Warnings
Seat belt warning ding (driver)
Enabled / Disabled
Seat belt warning ding (front passenger)
Enabled / Disabled
Seat belt warning ding (rear passengers)
Enabled / Disabled
Ding when key is left in the car
Enabled / Disabled
Ding when headlights are left on
Yes / No
Remote low Battery warning
On / Off
Heater & A/C
A/C blower speed at start-up
Off / Level 1
Auto-turn on A/C when AUTO button pressed (if needed)
Yes / No
Auto-turn on recirculate mode when A/C is on
Yes / No
Open vents to outside air when ignition is turned off
Yes / No
Auto-increase blower speed when front defroster is on
Yes / No
Ambient temperature calibration
-3°C / -2°C / -1°C / Normal / +1°C / +2°C / +3°C
Fan speed reaches its target…
Slowly / Normally / Fast
A/C power
Automatic / Full power
A/C ECO mode
Enabled / Disabled
Instruments: Displays & Nav
Instrument lights dimming sensitivity
Darkest / Darker / Normal / Lighter / Lightest
Instrument lights restoring sensitivity
Engine start indicator
On / Off
Display odometer after ignition is turned off for…
30 seconds / 1 minute / 10 minutes / Off
Lights: Automatic
Auto headlights activation threshold
Lights: Exterior
Lane-change turn signal auto-flasher count
Off / 3 flashes / 4 flashes / 5 flashes / 6 flashes / 7 flashes
Turn signal click volume
Low / Medium / High
Exterior light control
Enabled / Disabled
Coming-home lights duration
30 seconds / 60 seconds / 90 seconds / 120 seconds
Turn on marker lights when vehicle is unlocked via remote
On / Off
Turn on exterior footlight when smart key in range
Yes / No
Turn on exterior footlight when doors unlocked via remote
Yes / No
Turn on exterior footlight for…
Off / 7 seconds / 15 seconds / 30 seconds
Lights: Interior
Interior light control
Enabled / Disabled
Turn on interior lights when you shut off engine
Yes / No
Turn on interior lights when you unlock doors
Yes / No
Turn on interior lights when smart key in range
Yes / No
Dim interior lights after…
Interior footlight (bright when doors open, dim when driving)
Yes / No
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
Yes / No
Locking: Automatic
Wireless door locking
Enabled / Disabled
Auto-lock doors when moving
On / Off
Lock doors when shifting into gear
On / Off
Unlock doors when shifting into park (P)
On / Off
Unlock all doors when driver's door is opened
On / Off
Re-lock doors automatically if you unlock, but don't open a door within…
30 seconds / 60 seconds / 120 seconds
Locking: Beep & Blink
Blink turn signals when locking/unlocking with remote
Yes / No
Locking: Doors & Alarm
Unlock doors via remote
Driver's door on 1st press, all on 2nd / All doors on 1st press
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Warn (beep) when door can't be locked because it's still open
Yes / No
Warn (beep) when a window is still open when locking doors
Yes / No
Warn (beep) when sunroof is still open when locking doors
Yes / No
Disarm the alarm when unlocking with key from door lock
Yes / No
Locking: Smart Key
Stop monitoring for car key signal after…
0 - 5 days
After locking with smart key, don't allow re-opening within…
0.5 seconds / 1.5 seconds / 2.5 seconds / 5 seconds
Smart key location to start car
Front seats / Anywhere in vehicle
Open trunk via smart key
Disabled / Double click / Long press
Mirrors
Lower passenger-side mirror when in reverse gear
Default / User-specified
Parking Sensors
Parking sensor beep volume
1 / 2 / 3 / 4 / Max
Activate parking sensors in neutral (N)
Yes / No
Enable front parking sensors when in reverse (R)
Front / Front corner / Off
Enable rear parking sensors when in neutral or forward gear
Rear / Rear corner / Off
Mute Parking Support Alert (PKSA) beep when car is parked
Yes / No
Display temporary parking sensor muting status
Yes / No
Disable temporary muting of parking sensor above…
Automatic / 15 km/h / 20 km/h / 30 km/h
Front parking sensor range
Narrow / Wide
Rear parking sensor range
Narrow / Wide
Dash display mode
All / Undisp
Seats & Steering Wheel
Slide driver's seat back for easy exit
Off / Short / Standard
Seat memory is enabled when unlocked from
Driver's door / Any door
Trunk
Rear hatch open assistance
Enabled / Disabled
Rear hatch close assistance
Enabled / Disabled
Rear hatch max open level
1 / 2 / 3 / 4 / 5
Unlock via "One motion"
Rear hatch only / All doors
Open rear hatch via "One motion" remote
Disabled / Single click / Double click / Long press / Double click on unlock button / Long press on unlock button
Open/close power rear hatch via interior switch (click type)
Single click / Long press
Beep while opening/closing power rear hatch
Yes / No
Windows & Sunroof
Open windows via long-press on remote
On / Off
Close windows via long-press on remote
On / Off
Open windows and sunroof by turning and holding key in door lock
On / Off
Close windows and sunroof by turning and holding key in door lock
On / Off
Beep when opening/closing windows with remote
Yes / No
Open driver's window using single button press
Yes / No
Close driver's window using single button press
Yes / No
Open passenger's window using single button press
Yes / No
Close passenger's window using single button press
Yes / No
Rear-left window single-touch-close
Yes / No
Yes / No
Rear-right window single-touch-close
Yes / No
Yes / No
Passenger window single-touch-open from driver's switch
Yes / No
Passenger window single-touch-close from driver's switch
Yes / No
Rear-left window single-touch-open from driver's switch
Yes / No
Rear-left window single-touch-close from driver's switch
Yes / No
Rear-right window single-touch-open from driver's switch
Yes / No
Rear-right window single-touch-close from driver's switch
Yes / No
Also found the attached file.
All that can be done using some free apps and a Bluetooth obd2.
15NX200t-WithNavi-030115.pdf
Gabriel,
Great posts, thanks. Can you link the £4 device you got off eBay please?
Cheers
7 hours ago, Steve Oliver said:
Gabriel,
Cheers
https://www.ebay.co.uk/itm/OBD2-ELM327-V1-5-Bluetooth-Wireless-Car-Scanner-Torque-Auto-Scan-Tool-/363322230987?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
I have 2 of them. Both are working fine with Torque apk, but only one with Carista.
For the apk I use
https://forum.mobilism.org/ --travel section.
You can open/close the car using the button on the tailgate. Close to the opening button for the tailgate there is another one which is closing and opening the doors!
An easy way to see your car service history is using the Lexus link application.
1 hour ago, Rew1 said:
Purchased and on way. Thanks! 👍
You are welcome!
Let me know if you need need help with the application!
2 hours ago, Rew1 said:
You are welcome!
Many thanks, I will. 👍
It’s really easy and enjoyable to customize the Lexus with the OBD2 adapter. After over 4 years I finally got rid of the annoying beep when opening/closing the trunk. You can even set the intensity of the beeps.
13 hours ago, Rew1 said:
You are welcome!
Gabriel, I'm just preparing for the OBD2 arrival. I've downloaded Torque Pro. When connected to the dongle, how will I access the customisable settings you outlined? Thanks
Torque is not having those options. You need carista apk.
You can download it from the website adress posted above.
After you connect it to the car is super simple, just go in the second menu--I belive is called customization.  You will be able to change all the options described in my previous post.
I will post some pictures tomorrow.
Oh, great, glad I asked! 👍
The following settings were available specifically to your vehicle Nx 2015 using Carista:
Dings & Warnings:
      *ENABLED* / DISABLED
      *YES* / NO
      *ON* / OFF
Heater & A/C:
      YES / *NO*
      *YES* / NO
      *YES* / NO
      *YES* / NO
      -3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
      SLOWLY / *NORMALLY* / FAST
A/C ECO mode
A/C compressor noise reduction
      ENABLED / *DISABLED*
Instruments: Displays & Nav:
      *ON* / OFF
      *30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Lights: Exterior:
      OFF / *3 FLASHES* / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
      LOW / *MEDIUM* / HIGH
Lights: Interior:
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *7 SECONDS* / 15 SECONDS / 30 SECONDS
      *YES* / NO
      *YES* / NO
Locking: Automatic:
      *ON* / OFF
      ON / *OFF*
      *ON* / OFF
      *ON* / OFF
Locking: Doors & Alarm:
      DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Locking: Smart Key:
      5 days
      0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
      FRONT SEATS / *ANYWHERE IN VEHICLE*
      DISABLED / DOUBLE CLICK / *LONG PRESS*
Mirrors:
      DEFAULT / *USER-SPECIFIED*
Parking Sensors:
      *1* / 2 / 3 / 4 / MAX
      *YES* / NO
      FRONT / *FRONT CORNER* / OFF
      REAR / REAR CORNER / *OFF*
      YES / *NO*
      *YES* / NO
      AUTOMATIC / 15 KM/H / *20 KM/H* / 30 KM/H
      NARROW / *WIDE*
      NARROW / *WIDE*
Dash display mode
      ALL / *UNDISP*
Trunk:
      1 / 2 / 3 / *4* / 5
      REAR HATCH ONLY / *ALL DOORS*
      DISABLED / SINGLE CLICK / DOUBLE CLICK / *LONG PRESS* / DOUBLE CLICK ON UNLOCK BUTTON / LONG PRESS ON UNLOCK BUTTON
      SINGLE CLICK / *LONG PRESS*
      YES / *NO*
Windows & Sunroof:
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
Obtained with Carista 6.4.1 for Android.
Not sure if it is exactly the same as the list pasted above.
To speed up a voice command press again the button. It will stop that 20sec stupid monologue.
Very helpful tip about how to open a stuck petrol tank cover flap:
