2006 Lexus LS430
It appears the right hand side buttons on the rear centre console have no backlighting when the lights are on, but the others do. The buttons that are affected are the massage, head-rest and seat movement adjustment.
Similarly, the buttons for the Sport/Normal suspension and the Power/Snow gearbox mode have no lighting, whereas the High/Normal height adjustment does.
Is this hard to fix and what bulbs are needed? I have attached pictures.
Hi Dom
I cannot answer about the rear console but the front buttons (snow/pwr) use a bulb with green sheath over it part number 90010 - 01059
Replacment is straight forward once you have removed the switch panel
There is a thread here aswell:
36 minutes ago, cruisermark said:
Hi Dom
Thank you for the part number and guide to remove the panel!
7 minutes ago, steve2006 said:
Hi Dom,
Are your radio and AC buttons illuminated normally?
Yes, all other buttons are illuminated, just the two I mentioned. Thanks.
Good luck with your investigations and resolution of this problem
the other option would have been to just scrap the old girl :whistling:
I jest of course
