I had a small paint chip that underneath revealed a grey color, I assume is primer. When I applied the color match 3T5 the paint was much darker (very dark red.) Several more touch-up coats remained dark red not matching the infrared color at all.
Has anyone else experienced this? i have not tried adding white then the color match.
I have touched up my Sonic Red door edge which had a very small chip on. I used the two pot Lexus kit and followed the instructions but using a cocktail stick instead of a brush to apply the tiny bit of paint required. The base coat looks the incorrect colour until you put on the top coat. It then changes to the proper appearance. The area on my door edge is now undetectable after a mild polish.
Apologies in advance for asking but did you give the bottle a good shake before use?
Absolutely, for several minutes.
4 hours ago, Oracle said:
How did you get on @RiverFred? I need to do the same on mine prior to detailing.
Not sure what your question is (riverfred1@gmail.com)
Where did you purchase this kit? I went on the internet and cannot find Lexus two pot touchup paint kit.
You are in the UK I am in the USA, appreciate any help (riverfred1@gmail.com)
I was given the kit when I bought the car. I will look up the part number and let you know.
Should be this : "3T5 Sonic Red / Radiant Red / InfraRed PZ448-W3T51-09 (The lacquer in this kit is tinted to achieve the correct colour once finished)"
My Lexus 2 part touch up paint says do not shake before use?
As in how did you get on with using the touch up paint, did you take before/after pictures? I need to do the same for a small chip on my LC.
Regarding the part number of the paint kit, I have:
P2448-W3T51-09 New Sonic Red 3T5
Hope this helps.
Thanks for the part #.  I used 3T5 for my infrared paint and the paint was very very red. Did your first coat go on the same color, very red before applying the lacquer coat?
Also, on my 3T5 touch up paint the #'s below read: 00258003T521 (could be just the batch number)
On 2/8/2022 at 10:07 AM, NemesisUK said:
Have you applied the clear (lacquer) top coat?
Not yet, I assume 'clear' would not change the color.
As eightk posted and you have quoted ..
Still trying to figure out best solution as the paint touch up is much darker (blood red) than the car infrared color. I have not applied a clear coat yet because it says clear. I tested the 3T5 on white background and it matches the car color. I am guessing the grey color underneath the chip area is a primer chemical that caused the touch up color to turn much darker. Additional touch up paint remained the same dark color. I can always try a white touch up then the 3T5 if no other solution.
I would like to know if anyone else experienced the very very dark color and the clear corrected the color. It does not seem possible.
i think by 'clear' they mean it has no opaque content but it may be (and in this case is) tinted
Sorry for the late response, was the base paint coat when first applied much darker than the top coat that corrected the color? My base paint is a very dark red compared to the car color of infrared.
Still trying to figure it out, see the forum for my comments.
Mine has just arrived so I'll give it a go when the wind dies down a bit during the week.
Just to clarify my part number post was from googling the paint, not a result of actually owning something to paint… yet!
Weird-When the infrared color chip exposed a grey underneath the touchup paint turned darker, when chip exposed white underneath, very good touchup paint match.
I have used Chipex on my Cadoxton Slate LC with good results, it fills the chips and then you smooth it out they also mix the colour to you reg number.
  • 2 years later...
Just did a touch up on my LC. You are correct the clear coat is tinted. In fact it’s almost candy red (but still clear when dry).
Base coat was closer to copper than red!
Need both for an almost invisible repair.
For clarity, the clear coat is TINTED and not “clear”.
