1994 GS300 front suspension spring
FandS
Any ideas where I can get a replacement  front suspension spring for my elderly fathers 1994 GS300 ??
Nowhere seems to have any... Many thanks in advance for your help.
Hi Michael and welcome to the LOC.
Basically now obsolete with little or no remaining old stock but found these ( you should replace both anyway)
They are “sports” springs so probably a little lower and stiffer but will fit straight on plus here and available in the UK.
https://lexuspartsdirect.co.uk/product/lexus-phase-1-gs300-sport-front-spring-kit/
If the car doesn’t have “Sport” suspension already, then it might look a bit like it is nose diving if you only do the fronts. You’d be best off doing the rears as well, which are available too on the website Steve links to.
I had RS-R springs on my old Gen1. Don’t seem to be easily sourced over here, but can be got from Japan.
