Hi All new the the forum, and to Lexus. My neighbour has asked me to swap out his leaking rad on his LS460 2007 uk car, i have got the rad out but it seems to be larger than what all the suppliers tell me should be fitted, im told it should be 425mm x 708mm yet this one is 450mm, i dont know how these part numbers work so have attached a picture of the number from the rad, can anyone tell me where to get one from please?
The part number on the radiator you have removed doesn’t fully match the model or year for a 2007 LS460, Toyota part numbers are usually 5 digits-5 digits as shown below.
16400 RADIATOR ASSY
16400-38190   1 € 429.46
If you want OEM try Lexus Parts Direct for a price.
You can use megazip or amayama to check for correct part no. - when typing in your denso one on amayama, says 'permanently out of stock', so something fishy has occurred!
If you need more help, send a pm and I can have a quick scan as I use the sites weekly, it would seem the number listed by Steve is correct, but always worth a double check!
Cheers i have sent lexus parts direct an email, as i cannot see the dimensions on theres.  If it is correct its cheaper than the eBay one. Thanks
the price seems very good - its cheaper than what Amayama are quoting - lets hope its available - LPD are very good with speedy replies to emails
Just found some sports front coil springs on there for another member struggling to find some standards for an early GS300 which are now obsolete.
I have been chatting to LPD and have ordered there Rad, Lexus wanted £268 +vat  so LPD were cheaper. £285 with shipping and they say if its wrong they will take it back.
