Dimming the Nav screen at night
rob_clio172
Hey guys, as the title says.. is there a way of doing this? I'm finding at night its that bright its affecting my left eye from the glare. Is there not an option for it to go dim or change colour when the head lights come on?
Cheers
Not sure about when the headlights come on but there should be a control to the right of the steering wheel which allows you to dim the screen brightness. On mine one click sets it to automatic, its then dims when the light outside drops.
The one we have change navigation display after sundown to much darker automatic. If there is a setting that makes that happen I am not sure of. Entering a tunnel also change the display.
One of you reading this, that have read the manual, may be able to inform better.
Sorry what do you mean?
i.e., it's automatic, I assume. Same for mine - it just changes based on the outside ambient light.
Edited by PCM
Addition.
Thank you. Mine can be set as automatic or changed manually. You can also set it not to change at all. Little differences.
