Hello. I was wondering if it is easy enough to replace the rear indicator bulb on the left side? I tried to look at YouTube to see how people do it, but a lot of the videos are of slightly different models or the tail lights which involve taking off cladding on the back of the truck. The indicator is in the corner of the truck. The bulb has been glitchy for some time and I was able to temporarily push the bulb in the make it work, but now it has failed completely.
Are the any good resources how to do replace the bulb on the Lexus IS250 2007 model. Assuming it isn't too technical?
Thank you
Best regards
Jools
You definitely need to replace just rear indicator light? I am asking because it is so simple that I struggling to understand what would be confusing here.
Replacing reverse/fog lights is more complicated and requires removing boot-lid inside cover:
This is from Lexus owners manual, p458:
https://d24bc9lyrt5en5.cloudfront.net/Customer-Portal-Admin/emanuals/LEXUS/OM53A88E.pdf
Hi Jools. When you open the boot lid and look at the carpet along the rear of the boot, do you see 2 black plastic covers a few inches apart? Most bulbs are accessible from behind those plastic covers.
