Hi. Hope someone can help.
I have owned my RX 400h for just over a month. Love the car.
Over the past couple of weeks, I have noticed creaking noise from the rear only when I turn corners. Its sounds suspension related.
I have had two separate mechanics look at it and despite going for a drive and hearing the issue for themselves. Can not find a fault. The suspension all looks fine.
It seems to only happen when I am turning a corner. Straight and over bumps it is fine.
Its driving me nuts!!!!!!!
Has anyone else had a similar issue?
I want to avoid going to Lexus to sort it as it will cost a arm and a leg.
Any advice will be great.
Thanks in advance.
  • 1 month later...
Try lubricating the rubber door seals. You can order stuff on line to do this. A quick easy thing to do which might resolve this.
And where the folding back seats touch each other? I used silicon spray. It was amazing how much creaking they made.
