My gears only work in 1, 2 & 3. Will not change to 4,5 or 6.
What is the problem. Also heard that 3 different gearbox manufacturers were used in the IS 250 gearbox, with different parts what can be done to fix this problem
Take the car to someone with Techstream and get the codes read.
When was the last time the atf was checked or changed. How many miles on the clock?
What year is the car and where are you located?
