Can advise the step or a video to clean the vent filters on the Battery fan for a GS450H 2016 F Sport. I've had a look on line and can't find one.
Someone posted this here some time ago. I kept a copy for my future reference. Thanks to whoever it was!
Quote>
'Just some info on how to clean the ducts for the hybrid Battery cooling fan.
In my case its a 2014 gs300h with 120000 miles which is used as a taxi.
First remove the upper trim panel in the boot so that you can remove the trim panel that fits behind the rear seat, all this is to remove 1 retaining pin. Next is remove the rear seat base, it just pulls up, now remove the 4 12mm bolts holding the seat backrest in place and pull the base upwards, no need to remove the seat belts but pull the backrest towards the front seats to give a bit of room, behind the felt there are 3 black vent tubes that connect from each side of the car to the cooling fan, there are a few retaining pins to remove and then there is 1 of the retaining pins has to be removed from the boot side, at the fan end of both the side vent tubes is a mesh which gets clogged
 Can't upload pictures but both of my vent tubes were about 90% clogged.
Was an easy enough process and well worth doing.
Hope this might be helpful, '
<End quote
(PS - I haven't tried it myself yet)
Quote>
'Just some info on how to clean the ducts for the hybrid battery cooling fan.
<End quote
You're welcome, having to clean the filter isn't something that isn't widely known but is so important
    John
https://www.lexusownersclub.co.uk/forum/topic/128393-hybrid-battery-cooling/?do=findComment&comment=1180388
