Part Identification please!
Hi All,
We've had a 2013 RX450h since June to replace our written off Diesel Rav4 and are loving it so far.
Unfortunately, my wife has managed to push it into a tree stump and bend something radiator looking in fron of the passenger wheel.
Is anybody able to help me identify the bent part please?  Give me a better idea when phoning round garages in the morning.
Many Thanks!
~UQS~
59 minutes ago, Herbie said:
That's the aircon condenser if I remember correctly.
No, it's the transmission oil cooler and there should be an air duct on the front of it to make sure air passes thought the fins. Looks like the bracket at the top is still there, and the other one to the side where the pipes enter/exit - may just need to be bent back into place.
Make sure there is no leaks coming from it or the pipes - it there is then don't use the vehicle as you don't want to run the transmission with low fluid.
7 hours ago, steve2006 said:
You’re having some bad luck with cars at the moment Jon.
I'm guessing you've seen my other post elsewhere yesterday.
I think Colin was right with the Transmission Oil Cooler.
Yes it is the transmission cooler, it comes as a complete unit as shown with the cooler itself fitted inside the plastic housing.
Unfortunately there is no price stated on the parts database.
