O2 sensor
Hi first time posting on here, recently turbo charged my is200 having a few issues with o2 sensor as there is now only one in the downpipe. I am struggling with the ECU wiring so I only have to run one sensor does anyone have any pics of their wiring if they have done this cheers guys.
Hi Gareth,
I have attached the IS200 Engine ECU pin out which shows the connections for both O2 sensors if this helps.
You can also buy ( or even make) O2 emulators which produce the correct waveform to trick the ECU both are still connected.
Cheers bud I'll have a look tomo as I only have 1 bung in the down pipe I was hoping that I can wire the ECU to just run the one sensor I have wired it but I keep getting a o2 sensor bank 1 sensor 2 heater malfunction
