Anyone with a LS460 or 460L 2006 to 2012 able to kindly share the numbers printed at the back of their key fobs please? It may start with 14 followed by 3 letters. If anyone has a smart key card that will be even better if you could kindly share the code of the smart key card.
Thank you 😀
Hi ahmed
you might want to post up what problem you are encountering and someone might be able to help
I think members might not be comfortable posting key numbers
25 minutes ago, cruisermark said:
Hi ahmed
Fair point, just to clarify these numbers are not specific to one individual vehicle so not really a security issue. For example all LS460's in that date range should have the same code. Therefore,  members sharing this information are only sharing an FCC ID which is used across many vehicles. I need this just to cross reference the ls460 keys to other models. Unfortunately they don't print part numbers on the keys so these are the next best thing.
wouldn't the technical people at Lexus at the Centre ( wherever that may be )  have all this info at their fingertips ...  or close maybe :unsure:
Nope they only go based on what is available on their screen. The FCC IDs are not listed in their catalogue only part numbers and part numbers are only printed on the packaging. These same technical people have told me so many things aren't possible when in fact it is. They can only advise on things that are designed to work within the specifications they have documentation for.
