1993 cream color LS400 for sale in Oklahoma, U.S.
Is this a common problem with Toyota?  1993 LS400 190,000 miles. Good condition. Ignition & steering column locked. Is it a faulty anti-theft security lock?? Is it a common electrical issue with these cars? Do we need a new key? Going nuts here
If the steering lock has engaged which it sounds like it has you will need to turn  the steering wheel slightly and hold it there to reduce the pressure on the locking pin when trying to turn the key. Or just jiggle the wheel slightly when trying to turn the key, the lock should then release as the key turns.
I also noticed you have asked the same question on this and 2 other posts 4 hours ago, here in the UK that was at 3.00am so you were very unlikely to get a response at that time.
