Hi guys,
So I had engine light , vsc etc come up on my 06' gs430. I plugged in tech stream and It said p0031 bank1 sensor1. I brought a Bosch unit and fitted it today. to my relief it came out easy and fitted the new one .
The problem is I took the car for a drive and the lights stayed on. I Plugged the laptop back in afterwards and the same code is still in current and history - it won't clear.
I can't afford a lexus dealer (they probably wouldn't be interested in my 15 year old car anyway)
Has anyone else ever come across this??
The it was cylinder 1 side (passenger for UK)  in the manifold. That is bank1 sensor1 isn't it?
Yes
Did you clear the fault? If not then it will take three error free start/stop cycles for the code to clear.
I assume the Bosch sensor was specifically listed as compatible with your vehicle? It uses a wide-band air/fuel ratio sensor rather than a generic O2 sensor. I'd personally only use Denso sensors for a Toyota engine.
Yes tried to clear but the fault stays on current when on tech stream.  I thought I'd go Bosch as they have a good reputation
Just to finish this topic off, i drove the car for a few days to work and back with the light still on. Then after that to my amazement Techstream let me clear the code and it hasnt come back on since?? weird??
Lexus for you, the car had to make sure it was 110% happy with the replacement part 😀
  • Haha 2
