I'm looking for either a replacement switch cluster or the part number for my F Sport.
The cluster has the Auto Headlight switch and the tailgate release switch with the other 2 blanked off.
I have seen used replacements for Lithuania on yje usual auction site, but they have more switches,(HUD etc ) where mine is blank.
Can anyone let me know the part number for replacement, or will a used part with extra switches install and work out.
I somehow managed to crack the pushbutton and Lexus won't fix it under warranty.
TIA.
Chris.
Just get the eBay one from Lithuania, it won't matter that the extra switches aren't connected to anything.
Good answer. When I had my RX450h I kept cracking my knee on that panel getting in and out of the car. Once it dropped inside the das5 and Lexus Cheltenham kindly refitted it. Via removing the end of the dash panel.
So I ordered the part off Flea Bay from the Lithuanian guys, turned up today and is absolutely immaculate.
Now I could do with some advice on how to fit this replacement part, is it doable from the end panel  as suggested above ?
Hi Chris,
Like Les I have in the past knocked mine back into the dash. All I can say is that my dealer took around 5minutes to replace it. When I asked how they said they just took the end off the dash and clicked it back in so I guess that it will be easy to access the rear of the switch and swap over the wires. But I have no idea to remove the end of the dash!
Bri
