Rear camber bolt IS300
Shizukesa
Hey everyone,
I'm struggling to find out the part numbers for the camber bolt, nut and camber plate? Basically the nut and bolt have cross-threaded and I'm waiting for a second alignment.
I've found these parts but I'm honestly not sure if they're correct. I need all parts that connect the rear toe arm to the subframe.
https://lexuspartsdirect.co.uk/parts/lexus-is/lexus-is-phase-i-1998-2005/lexus-is-1-steering-suspension/lexus-is-phase-1-camber-adjust-washer-plate/
https://lexuspartsdirect.co.uk/parts/lexus-is/lexus-is-phase-i-1998-2005/lexus-is-1-steering-suspension/lexus-is-phase-1-rear-toe-cam-bolt/
https://lexuspartsdirect.co.uk/parts/lexus-is/lexus-is-phase-i-1998-2005/lexus-is-1-steering-suspension/lexus-is-phase-1-rear-camber-adjustment-nut/
Any help would be appreciated.
Paul
Top item comes up as 18190-30060 (bolt) so the part listed may be an upgraded part number ending in 80, the middle and bottom parts are a confirmed match on part numbers.
There is also another part which looks like a washer ( described on parts list as “piece, rear suspension arm 48756-53010) which fits between the arm and the adjuster.
Information is based on the JCE10R-AEAVFQ model.
Thanks a lot for your help.
So I basically need:
48198-30060/80
48190-30060
90170-12030
48756-53010
If I call Lexus, do they still make/stock these parts? I'm not sure how legit that website is from where I posted the links.
Thanks a LOT for your help!
Paul
7 hours ago, steve2006 said:
According to the database all the parts are still available, they may have to order them in but a couple of days should be all it takes. 😀
Called Lexus and got what I needed 🙂 although they did say I only needed 2 parts. Perhaps I'll have to call for more later.
Thanks a lot for your help!
