I'm looking to carryout a pre-emptive replacement of the water pump on my IS, I've identified the pump , my choice being the ASIN WPT-137 version, but not sure about the belt, any one know which one is required?
Had to do this last year to mine to - got the water pump from Autodoc - £80 delivered. And used a ContiTech belt https://www.carparts4less.co.uk/search/202779115
Water pump also available at Carpart4less https://www.carparts4less.co.uk/search/201820715 but a bit priceyer
Don't forget to buy the coolant. full system capacity is 9.1L I believe but most people have said they got out around 6L.  Lexuspartsdirect is a good shout for OEM coolant -you need the pink one not the red
https://lexuspartsdirect.co.uk/parts/lexus-lc/lexus-lc-2016-present/lexus-lc-engine-service-kits/lexus-super-long-life-pink-coolant-5l/
  • 2 years later...
Hi there,
I will be replacing the water pump on my 2009 IS220d soon, does anyone know the torque settings for the water pump bolts?
Also is it worth changing the ancillary belt while I'm on?
Matt
Perhaps check out the video above around 24 minutes in ? 😀
Yes change the belt at the same time.
Above vid was 250 and not 220👍
