Above has broken off.
The plastic around the two front fixing screws having broken away.
Has anyone else experienced this problem?
Ours did the same and it was replaced under warranty. I posted about it at the time so you should be able to find it through the search function, although I will say that the search facilities of this board are quite abysmal.
Herbie posted about this on 3rd Gen RX450h.  He had a bit of Goodwill from his dealer who replaced it FOC if I correctly recall so it does seem to be a possible weak spot.
Edit.  You just replied whilst I was sending my reply Herbs.
Just make sure that your search words are ssspelt korrectly, old Pal.🤣🤣
Agree,  I find the searching same as you Herbie.
throw the following into google
site:lexusownersclub.co.uk herbie armrest
and you get this as the first hit:
