I can not locate interior fuse board on my 2009 RX450h can some one please help
52 minutes ago, sergeigto said:
Thanks for your replay , however thats for 2003-2008 rx400h model , mine is 2009-2012 rx450h
and fuseboard is not there (as you can see in my pictures )
Lay down with your head looking up behind the glove box in the passenger footwell. I'm almost certain it's there.
Thanks for pointing out in to right direction 👍
Much appreciated
it is in the passenger footwell , behind panel at the bottom of the glovebox ( panel needs removing)
Was not the first piccy (in the Handbook?) showing a left hand drive, which if true would mean the passenger side on a RH Drive ?
it is
however that's not exactly correct , first of all it says Drivers side( which is wrong for RHD cars)
