Does anyone know how to remove the small rightmost panel on the boot floor? This one:
On my car this panel is loose, it looks like someone has dislodged or removed it at some point and not reinstalled properly. If I pull it up a bit I can just about see one of the white trim clips underneath has broken. I want to take it out and refit properly with replacement clips. So far I haven't applied a huge amount of force, but it seems to be stuck on the metal luggage hook (which you can't see in that picture). Any thoughts?
Looks like the Mark Levinson amplifier or something is under there as well.
Have a look at this video around the 2 minute mark. There should be a 10mm bolt under the luggage hook.
Thanks! Nailed it!
